Heeya Bitcraze,
I've been flying your drones for quite a while and having great fun.
Im currently working on a show that has 9 drones in it, and im noticing that the more drones are in a show the longer it takes to connect to them.
For my 9 drones its takes about 3 minutes to connect, download the parameters and get a position. This is not a problem by itself but when one CF has a problem with its position we will need to run the entire sequence again (and sometimes even a third or forth time). As you can see we are losing more than 15 minutes if that happends...
Is this something you have experienced yourself?
Im running high-level commander scripts, on a single radio (2M bitrate, default channel), using the VM.
I would be helped very much if either the delay on reconnecting would be smaller or we could reconnect to individual drones.
Thanks in advance!
Greetings,
Yoyasp
Long time connecting mulptiple drones
Re: Long time connecting mulptiple drones
I will try to help by throwing back some questions
- Have you tried different channels before? There is a radio test that you can try out (make sure to read the instructions in the comments), or you can use a spectral analyzer
- Are you currently using only 1 crazyradio PA? You can also try to connect more if you can, which might speed things up a little. You can change the radio number: radio://0/80/2M/E7E7E7E7E7 to 1 and 2. It is also good practice to put the groups in a different channel.
