I apologize if this is a silly question I am very new to the crazyflie environment and the LPS nodes.
So I set up the crazyflie VM and now I am a bit stuck setting up the LPS nodes. I was trying to follow these steps:
https://www.bitcraze.io/documentation/t ... ng-system/
I am on the tools step and I set up everything up to the USB access. So since I am running the VM which is Linux on a computer running linux I can just skip the follow steps right? Cause the setup for windows and mac do not apply.
So if yes how do I launch the LPS-tools for the setup of the nodes?
LPS settup
Re: LPS settup
Have you followed these readme instructions as well ?
If you can not find the lps-tools repository, You should probably git clone the lps-tools project in the projects folder on the VM and then follow the running instructions in the readme instuctions.
btw I'm moving this thread to the LPS group
curiositycat
Re: LPS settup
Hello!
Thank you for your reply!
So Yes I have looked at those two links and I have the LPS tools cloned. I apologize if this is extremely trivial. But how do I launch the tools?
I already have the USB access on Linux set up with the 99-lps.rules.
Re: LPS settup
[So according to the running instructions on the readme file.
you would first need to install it by running this from the lps-tools folder
make sure that you have the python package pyqt5 installed as well.
And then you run the following command from the same folder:
pip3 install -e .And then you run the following command from the same folder:
python3 -m lpstools
