AI deck with Flow v2 ?
Discussions about the AI-deck
q666
Post by q666 »
Hello
The compatibility matrix for the decks doesn't include AI deck, will these two expansions be compatible or would just the AI deck be sufficient enough for a pre-programmed flying setup. And will there be a Crazyflie + AI deck bundle 8-)
Re: AI deck with Flow v2 ?
First of all, I moved the topic to the right place ;) There is actually an AIdeck group available, so congrats you are the first one!
Are you sure that you are looking on the right place? The AI-deck is existing in the compatibility matrix: https://www.bitcraze.io/documentation/s ... eck---deck. It is compatible with the flow v2. Maybe you were still looking at the wiki?
