Hello
I just got my second CF and even tried to fly a couple of minutes (flights were normal without falling). Then I shut it off, and when a few hours later tried to turn it on again, it did not work. When I turn it on (like from the battery and at the attached USB) red and green ice blink once and go out, and only the blue lights. In the client CF is not detected and connection are not possible. What shall I do?
Perhaps CF software is broken (I tried to make some hacks and when I download it something went wrong)? But how can I fix it and restart the original program if I have no connection with the CF?
(SOLVED) Broken CF
slab105
(SOLVED) Broken CF
slab105
Re: Broken CF
SOLVED! I did it again
I just run bootloader and install original software and now all is OK.
Sorry and thanks
Sorry and thanks
