[SOLVED] How to access stabilizer data from deck
imranmomtaz
Post by imranmomtaz »
hello,
I am programming a new software deck which will work using some stabilizer data, namely - sensorData, control, and motor. However, I am not being able to access these data. I have written a deck which has following content under the while(1) loop:
while(1){
        // DEBUG_PRINT("in_value: %f, %f, %f, %f, %f, %f\n", sensorData.gyro.x/150, sensorData.gyro.y/150, sensorData.gyro.z/150, sensorData.acc.x/150, sensorData.acc.y/150, sensorData.acc.z/150);
        tick++;
        // Error model input preparation and evaluate
        // Saving old inputs
        DEBUG_PRINT("mod: %d\n",tick % 100);
        if (tick % 100 ==0){
          sensorsAcquire(&sensorData, tick);
          for (int ii=0;ii<6;ii++){
            inModelIMUOld[ii] = inModelIMU[ii];
          inModelIMU[0] = sensorData.gyro.x/150;
          inModelIMU[1] = sensorData.gyro.y/150;
          inModelIMU[2] = sensorData.gyro.z/150;
          inModelIMU[3] = sensorData.acc.x/150;
          inModelIMU[4] = sensorData.acc.y/150;
          inModelIMU[5] = sensorData.acc.z/150;
            // Preparing whole input for model
            inModelIMU[6+ii] = inModelIMUOld[ii];
            outModelIMU[ii] = 0;
          // DEBUG_PRINT("tick: %d\n",tick);
          DEBUG_PRINT("in_value: %f, %f, %f, %f, %f, %f\n", inModelIMU[0], inModelIMU[1], inModelIMU[2], inModelIMU[3], inModelIMU[4], inModelIMU[5]);
          get_inference_IMU(&inModelIMU,12/2,&outModelIMU);
          // vTaskDelay(M2T(100));
          DEBUG_PRINT("ou_value: %f, %f, %f, %f, %f, %f\n", outModelIMU[0], outModelIMU[1], outModelIMU[2], outModelIMU[3], outModelIMU[4], outModelIMU[5]);
          errorModelIMU[0] = outModelIMU[0] - sensorData.gyro.x/150;
          errorModelIMU[1] = outModelIMU[1] - sensorData.gyro.y/150;
          errorModelIMU[2] = outModelIMU[2] - sensorData.gyro.z/150;
          errorModelIMU[3] = outModelIMU[3] - sensorData.acc.x/150;
          errorModelIMU[4] = outModelIMU[4] - sensorData.acc.y/150;
          errorModelIMU[5] = outModelIMU[5] - sensorData.acc.z/150;
Please advise the best way on how to access these data. In the above code, it reads all zeros as the sensor readings.
Re: How to access stabilizer data from deck
So sensorAcquire is not returning actual values, only zeros? That is not good if that is not working, since there are some controllers relying on this as well.
Are you sure that sensorAcquire is actually reached? Did you put an debugprint in there to be sure?
imranmomtaz
Thank you for your reply. I later found out that there was an issue in the variable assigning. I changed the scope of sensorData at stabilizer,c and used 'extern' operator in newDeck.c and now it is working according to expectation. Thanks.
