I was messing around with custom firmware and flashed a simple program that just lit up the right green LED. Well, now if I try to flash the original firmware, my LED program keeps on running. I've tried it with the ST-Link, and it says it flashed and everything, but it clearly doesn't. My LED program clearly still runs.
If I try using
then it can't find my Crazyflie even though I can put it in bootloader mode (right blue LED blinking). The interesting thing is, if I simply have my LED program running, and I use
with
set in the Makefile, it's able to find and connect to the Crazyflie and put it in bootloader mode! Except that it isn't able to flash anything to it, and exits with:
Failed to warmboot
make: *** [cload] Error 255
Anyone have any idea what could be going on?
Thanks.
