sketchup model
sketchup model
had my crazyflie quadcopter for a few weeks now, pretty impressed by how stable it flies given it's size!
I wanted to look at designing my own crazyflie frame for 3dprinting after reading about Vger's experiments in another thread:
http://forum.bitcraze.se/viewtopic.php? ... ilit=frame
couldn't find any 3dmodel that I can use for reference, so I made my own, from the schematics on the wiki page and a bit of measuring.
thought I'd share.
distances (motor to motor / propeller diameter etc) should be mostly accurate, maybe +-0.5mm
eric
thought I'd share.
eric
- Attachments
- cf_model_s.zip
- superseded - see cf_mocel_s_revA files below
- (229.67 KiB) Downloaded 1184 times
Re: sketchup model
Hi Eric,
That's a really nice model. Great work!
If you haven't seen it already we have a repository for mechanical parts where we store various models and drawings. Would you mind if we added your model so that people could find it more easily? Any chance you have a Pro version of SketchUp and can export the model in DXF as well?
/Marcus
/Marcus
Re: sketchup model
thanks!
please do add it to the repository! I hadn't realise there's a mechanical section in the repository
I can export a dxf, but it'll have to be sometime next week, currently out and about...
(or someone else with sketchup pro might be able to help)
E
E
Re: sketchup model
Whoaaa O_O That's indeed a nice model! We really need a karma plugin for this board
Re: sketchup model
Great! Both the files are added to the mechanics repo.
Re: sketchup model
while working on my crazyflie frame today, I noticed the centre point I used for rotation in my previous model was slightly off.
fixed it, so here is the revised version of the model, in sketchup and dxf format.
Eric
Eric
- Attachments
- cf_model_s_revA dxf.zip
- dxf format
- (244.26 KiB) Downloaded 1170 times
- cf_model_s_revA skp.zip
- revisionA, sketchup 7
- (210.18 KiB) Downloaded 1123 times
Re: sketchup model
Great! The models that are in the mechanical repo have been updated as well.
markusw1984
Re: sketchup model
Hi Crazyflie Team,
i´m interested in creating my own crazyflie body. is it possible to offer a STEP file, where a quadcopter is included?
Best wishes,
Markus
Best wishes,
Markus
Re: sketchup model
I'm not completely sure what you are meaning with "where a quadcopter is included"?
