I have dug out my old 10DOF crazyflie 1.0 and tried to revive it. Successfully reflashed crazyradio dongle w/ 0.53 so it became visible on my Mac running Mojave. cfclient starts, finds the radio:
I was also able to use coldboot through the client (reset button seems not to work though, not sure if for soft or hardware reasons, it feels super soft and there's no "click" in it anymore) and flash 2017.06 firmware
copter initialises, shows up on scan, can be connected to
INFO:cflib.crazyflie:Callback->Connection initialized[radio://0/10/2M]
INFO:cflib.crazyflie:We are connected[radio://0/10/2M], request connection setup
INFO:cflib.crazyflie:Callback->Connected to [radio://0/10/2M]
and the console tab shows:
K].
ESTIMATOR: Using estimator 1
MPU6050: Self test [OK].
HMC5883L: Self test [OK].
MS5611: Self test [OK].
SYS: Free heap: 1288 bytes
However, at no point motors are initialiased - no twitch from propellers.I didn't do any soldering on it for, well, years, and it flew last time I saw it. I have tried disconnecting the battery entirely (I suspect it might be dead anyway, will replace), but motors are not initialising on usb power either. Propeller test button in Console tab is greyed out. FWIW, I can't see any physical shorts between M1/M2 motor connection pad, just in case.
Any practical suggestions on how to debug what has died (and whether I can fix it) would be very much appreciated.
Crazyflie 10DOF 1.0 no motors
Re: Crazyflie 10DOF 1.0 no motors
The motors are connected directly to the battery to minimize resistance so a battery is needed for the motors to run.
mbravo
So dead battery equals no motors...tobias wrote: ↑Mon Feb 03, 2020 12:47 pm The motors are connected directly to the battery to minimize resistance so a battery is needed for the motors to run.
While we are at it, could I ask for some specs (or a link to some ) for crazyflie 1.0 compatible battery? Maybe an aliexpress/seeedstufio link?
Many thanks in advance!
Unfortunately I don't have any direct suggestions but in this wiki page you can find all the spec about the battery and connector. From there you should be able to find something similar. Possible you would have to change connector on the CF1 to make it work with today's common batteries.
