Crazyflie stops booting with a Flow Deck V2
romi01
Whenever I plug in a Flow Deck, the Crazyflie v2 only lights up two leds, one blue and one red. When I disconnect the Flow Deck, the Crazyflie starts up normally. Is something wrong with my Crazyflie?
Re: Crazyflie stops booting with a Flow Deck V2
That is not good indeed, but there is probably something wrong with your flowdeck. Are you sure that the flowdeck was mounted on correctly like explained in here ? https://www.bitcraze.io/docs/cf2_expansiondecks/. Has it every worked before?
Could you connect to the crazyflie though the cfclient and copypaste the output in this forum thread?
