More powerful motors
r0b0tn1k
Post by r0b0tn1k »
I see that there are there are a few more powerful motors out there.
But I'm confused as I the default motors dont have CCW / CW markings on them, while the 7mm motors on the internet have those.
If I get motors like this, will the CrazyFlie be able to work with them?
Are there any specific motors you would recommend?
Are there any specific props you would recommend?
whoenig
Re: More powerful motors
Post by whoenig »
I used https://www.amazon.com/BETAFPV-19000KV- ... way&sr=8-3 with the stock Crazyflie propellers before. The motors are much more powerful (~2.6 thrust-to-weight ratio rather than 1.5), but they also tend to burn out after a while. The connectors are identical, but you'll need to swap the polarity of the black/white motors for it to spin in the correct direction. Works very well for more aggressive flight maneuvers.
kitz
Post by kitz »
Will a stronger motor be able to carry more weight?
Or is replacing with a stronger motor mostly for faster speed?
