Crazyflie dimensions/technical drawing
Adlerritter
Post by Adlerritter »
I'm currently working on a test bench for the Crazyflie 2.0/2.1 for my university. For this I would need the exact dimensions of the drone.
A technical drawing would be very helpful (assembled or the individual components).
Even better would be a direct CAD file if that would be possible. Many thanks in advance.
Friendly greetings from germany
Re: Crazyflie dimensions/technical drawing
Since you also sent us a mail, I copy-paste here the answer Kristoffer sent you so that more can be helped by it. Lets continue the discussion here :-).
There are some models of the CF 2.0 in https://github.com/bitcraze/bitcraze-me ... ter/models that might be useful. Crazyflie 2.1 has the same dimensions except for some minor changes around the battery cable.
The component placement pdfs should also have the correct dimentions but there are no measurements: https://wiki.bitcraze.io/_media/project ... cement.pdf
Let us know if this does not solve the problem, we can probably generate something better for you if needed but would require some more work.
