I have this recent issue that I have not been able to solve a few days ago I was able to connect to my crazyflie through the client in the VM, but today I scan for the drone and it does not find it. I am not really sure where to even start trying to solve this issue.
Crazyflie Client not finding drone on the VM
smickus
Re: Crazyflie Client not finding drone on the VM
Start by making sure the USB settings are OK. If it worked the other day, it is likely you changed some setting that breaks the USB communication from the client to the physical radio.
Another possibility is that you have changed the address of the drone, this would give the same symptoms. If you have not opened the dialog box where you changed the address, please disregard this, it will not happen as a side effect of other actions.
