Swarm and UAV Trajectory
gabrielalima
Post by gabrielalima »
In CF 2.0, I'm used to swarm flying using high level functions.
And recently, I tested on an aircraft the UAV trajectory package, where you unload a trajectory based on polynomials ...
Now I would like to join these programs. Swarm and trajectory. But I'm having problems ...
I created a file to upload on each aircraft the trajectory. Okay, apparently it worked.
And I tried to adapt an example of swarm, to work with the command: commander.start_trajectory
But it doesn't work well ... Questions about what to send in run_sequence ..
Swarm
import time
import csv
import datetime
import numpy as np
import cflib.crtp
from cflib.crazyflie.swarm import CachedCfFactory
from cflib.crazyflie.swarm import Swarm
# Change uris and sequences according to your setup
URI1 = 'radio://0/81/2M'
URI2 = 'radio://1/82/2M'
###    x   y   z  time
##sequence1 = [
##    (-0.7,-1.2,0.8,2),
##    (-0.7,0.0,0.8,2),
##    (0.0,0.0,0.8,2),
##    (0.8,0.0,0.8,2),
##    (0.8,-1.2,0.8,2),
##    (0.0,-1.2,0.8,2),
##sequence2 = [
##    (-0.7,1.5,0.8,2),
##    (0.0,1.5,0.8,2),
##    (0.8,1.5,0.8,2),
##    (0.8,0.0,0.8,2),
##    (0.0,0.0,0.8,2),
##seq_args = {
##    URI1: [sequence1],
##    URI2: [sequence2],
# List of URIs, comment the one you do not want to fly
uris = {
    URI1,
    URI2,
x1_vetor = []
y1_vetor = []
z1_vetor = []
x2_vetor = []
y2_vetor = []
z2_vetor = []
    log_config = LogConfig(name='Kalman Variance', period_in_ms=100)
    log_config.add_variable('kalman.varPX', 'float')
    log_config.add_variable('kalman.varPY', 'float')
    log_config.add_variable('kalman.varPZ', 'float')
    var_y_history = [1000] * 10
    var_x_history = [1000] * 10
    var_z_history = [1000] * 10
    threshold = 0.001
        for log_entry in logger:
            data = log_entry[1]
            var_x_history.pop(0)
            var_y_history.pop(0)
            var_z_history.pop(0)
            min_x = min(var_x_history)
            max_x = max(var_x_history)
            min_y = min(var_y_history)
            max_y = max(var_y_history)
            min_z = min(var_z_history)
            max_z = max(var_z_history)
            # print("{} {} {}".
            #       format(max_x - min_x, max_y - min_y, max_z - min_z))
                    max_z - min_z) < threshold:
                break
def reset_estimator(scf):
    cf = scf.cf
    time.sleep(0.1)
    wait_for_position_estimator(cf)
def activate_high_level_commander(scf):
    scf.cf.param.set_value('commander.enHighLevel', '1')
def activate_controller(scf):
    # 1-PID 2-Mellinger
    controller = 2
    scf.cf.param.set_value('stabilizer.controller', controller)
def run_sequence(scf, args_dict=seq_args):
    global x1_vetor
    global y1_vetor
    global z1_vetor
    global x2_vetor
    global y2_vetor
    global z2_vetor
    trajectory_id = 1
    commander = scf.cf.high_level_commander
    commander.takeoff(0.8, 2.0)
    time.sleep(3.0)
    relative = True
    commander.start_trajectory(trajectory_id, 1.0, relative)
    time.sleep(duration)
    commander.land(0.0, 2.0)
    time.sleep(2)
    commander.stop()
if __name__ == '__main__':
    factory = CachedCfFactory(rw_cache='./cache')
    with Swarm(uris, factory=factory) as swarm:
        swarm.parallel_safe(activate_high_level_commander)
        swarm.parallel_safe(activate_controller)
        swarm.parallel_safe(reset_estimator)
        swarm.parallel_safe(start_position_printing)
        swarm.parallel_safe(run_sequence, args_dict=seq_args)
gabrielalima
Re: Swarm and UAV Trajectory
Problem solved!! :D
