System startup
juliemac
System startup
1) Power computer
2) plug in the controller and have it recognised
3) Start the flight program
4) start up the quad.
Seems simple enough, but I am having trouble getting responses back at the PC reliably.
Am I missing something?
Re: System startup
I'm not completely sure what you mean. Is it the telemetry data that isn't reliable (bad radio connection)? Or the response from the controller? In the controller case and if it is a PS3 conntroller it can be that you need to press the middle "PS" button.
foosel
- Contact:
Re: System startup
Also make sure that upon connection you do not select the address that starts with "debug:" but the one that starts with "radio:"
juliemac
Re: System startup
Sorry this took so long.
I start the software and select the controller. Thats good.
Select the connection that states Radio. I can see the data leds blink faster, but no response when I tip the copter. The cmd screen states it cant start a timer be cause an older one is running and a lot off error codes stating that the log for XXX cannot be started.
Moving the controller knobs I can see a result, and logged in the cmd screen. Still no change in the crazyflie.
DesTinY
- Member
Re: System startup
Have you mapped your controller pads in the "Input device->Configure device mapping" menu!? Have you saved your Profilea and restarted the CF Client!? Don't forget to detect a button as "Killswtich" (this button can block the thrust).
BTW: It is recommended to use 250Kbit/s as Radio bandwith.
juliemac
Re: System startup
I mapped the controller and saved it. Restarted the software, selecting the controller.
I had it set on 1mbs, but moved it down to the 250kbs. I'm still having trouble.
It seems like if I get the response back from the crazyflie, I have no control, but if I have control, no access to the crazyflie...
I have rebooted the system several time trying to kill this ghost timer thinking that might help. It does not show in the system manager.....
I'll try again tomorrow night.
juliemac
Re: System startup
Ok. (I'm a geek and I am stumped.
The PC is windows 7 pro. I deleted the old install and re-installed the client as administrator.
I DL'd the firmware and reflashed the processor without verify.
Set the radio at 250kbs on channel 10.
Closed the client and restarted it.
I am still getting the same error where it cannot create the LOG file. Could this be a Win 7 bug?
Any thing else I can try?
Re: System startup
Are you running the latest software on both the Crazyflie and the cfclient?
The timer warning is none critical and it should run with them. I have them as well. Here is my output:
INFO:cfclient.utils.config_manager:Parsing [Generic_OS_X.json]
INFO:cfclient.utils.config_manager:Parsing [PS3_Mode_1.json]
INFO:cfclient.utils.config_manager:Parsing [PS3_Mode_2.json]
INFO:cfclient.utils.config_manager:Parsing [xbox360_mode1.json]
INFO:cfclient.utils.logconfigreader:Parsing [stabalizer.json]
INFO:cfclient.ui.tabs.FlightTab:Changed flightmode to Advanced
INFO:cflib.crtp.radiodriver:v0.51 dongle with serial N/A found
INFO:cflib.crazyflie:Callback->Connection initialized[radio://0/10/250K]
INFO:cflib.crazyflie:We are connected[radio://0/10/250K], request connection setup
INFO:cflib.crazyflie:Callback->Connected to [radio://0/10/250K]
INFO:cflib.crazyflie:Callback->Connection setup finished [radio://0/10/250K]
WARNING:cflib.crazyflie:ExpectAnswer: ERROR! Older timer whas running while scheduling new one on [2]
INFO:cflib.crazyflie.log:Have successfully logging for block=1
WARNING:cflib.crazyflie.toc:Unable to find variable [stabalizer.roll]
WARNING:cflib.crazyflie.log:Log: stabalizer.roll not in TOC, this block cannot be used!
WARNING:cfclient.ui.tabs.PlotTab:Could not setup log configuration!
INFO:cflib.crazyflie.log:Have successfully logging for block=2
INFO:cflib.crazyflie.log:Have successfully logging for block=3
INFO:cflib.crazyflie.log:Have successfully logging for block=4
juliemac
Re: System startup
Ok. I unloaded the client, rebooted and reinstalled the client and flashed the quad.
It started right up!
The cat is really unhappy right now. One whap with a quad blade and....
Many thanks guys!
Got to go. Lots of charge left.
Many thanks guys!
juliemac
Re: System startup
Ok. I stopped the client, closing it.
Ate dinner...
Then restarted.
No all I see is the battery voltage (3845mv) but no return values for pitch & roll.
Arrgh
Ate dinner...
Then restarted.
Arrgh
