Buffer Error when make cload
snyderthorst
Post by snyderthorst »
I sometimes get the error:
make cload
python3 -m cfloader -w radio://0/100/2M/E7E7E7E727 flash  cf2.bin stm32-fw
Reset to bootloader mode ...
  File "/home/thomas/Desktop/crazyflie-clients-python/src/cfloader/__init__.py", line 139, in main
    if bl.start_bootloader(warm_boot=True):
  File "/usr/local/lib/python3.6/dist-packages/cflib/bootloader/__init__.py", line 89, in start_bootloader
    started = self._cload.reset_to_bootloader(TargetTypes.NRF51)
  File "/usr/local/lib/python3.6/dist-packages/cflib/bootloader/cloader.py", line 105, in reset_to_bootloader
    struct.unpack('<BB', pk.data[0:2]) != (target_id, 0xFF)
struct.error: unpack requires a buffer of 2 bytes
when I try to flash the CF with a new firmware. make and make clean work fine, only when I try to make cload and at that only sometimes. It used to flash every time and I haven't changed anything except for values in pid.h and crtp_commander_rpyt.c
Re: Buffer Error when make cload
Could you let us know how you have installed the cflib and the cfclient? The cfloader is part of the crazyflie-client-python, but we need to know how old the version is that you are using.
sstroobants
Post by sstroobants »
For me, pulling the latest version of the client and python libraries and reinstalling them solved this issue!
snyderthorst
I'm trying to reinstall the crazyflie client, but I'm getting the following error message:
Obtaining file:///home/thomas/Desktop/crazyflie-clients-python
Requirement already satisfied: PyYAML in /usr/lib/python3/dist-packages (from cfclient===2019.01-18-g9fb3ab6)
Requirement already satisfied: appdirs>=1.4.0 in /usr/local/lib/python3.6/dist-packages (from cfclient===2019.01-18-g9fb3ab6)
Requirement already satisfied: cflib>=0.1.7 in /home/thomas/Desktop/crazyflie-lib-python (from cfclient===2019.01-18-g9fb3ab6)
Requirement already satisfied: pyqtgraph>=0.10 in /usr/local/lib/python3.6/dist-packages (from cfclient===2019.01-18-g9fb3ab6)
Requirement already satisfied: pyzmq in /usr/local/lib/python3.6/dist-packages (from cfclient===2019.01-18-g9fb3ab6)
Requirement already satisfied: qtm>=2.0.2 in /usr/local/lib/python3.6/dist-packages (from cfclient===2019.01-18-g9fb3ab6)
Requirement already satisfied: quamash==0.6.1 in /usr/local/lib/python3.6/dist-packages (from cfclient===2019.01-18-g9fb3ab6)
Requirement already satisfied: pyusb>=1.0.0b2 in /usr/local/lib/python3.6/dist-packages (from cflib>=0.1.7->cfclient===2019.01-18-g9fb3ab6)
Requirement already satisfied: numpy in /usr/local/lib/python3.6/dist-packages (from pyqtgraph>=0.10->cfclient===2019.01-18-g9fb3ab6)
Installing collected packages: cfclient
  Found existing installation: cfclient 2019.01-18-g9fb3ab6
Exception:
  File "/usr/lib/python3/dist-packages/pip/basecommand.py", line 215, in main
    status = self.run(options, args)
  File "/usr/lib/python3/dist-packages/pip/commands/install.py", line 360, in run
    prefix=options.prefix_path,
  File "/usr/lib/python3/dist-packages/pip/req/req_set.py", line 778, in install
    requirement.uninstall(auto_confirm=True)
  File "/usr/lib/python3/dist-packages/pip/req/req_install.py", line 703, in uninstall
    '(at %s)' % (link_pointer, self.name, dist.location)
AssertionError: Egg-link /home/thomas/Desktop/indoor-collective-robotics-testbed/crazyflie-clients-python/src does not match installed location of cfclient (at /home/thomas/Desktop/crazyflie-clients-python/src)
➜  crazyflie-clients-python git:(master)
Is there a way to uninstall the previous version before reinstalling? Or do I just have to delete all the files?
You can run "pip3 uninstall cfclient" and "pip3 uninstall cflib" a couple of time to make sure you have uninstalled existing installation.
