a question about multi-range deck
wumenghust
Post by wumenghust »
Dear All:
I am using multi-range deck and flow deck to do test. There is a communication between crazyflie2.0 and PA radio, however, when I am running python program such as multiranger_push.py, the crazyflie doesn't fly.
I hope to get help from you.
Best
Meng
Re: a question about multi-range deck
Hi Meng,
Did you change anything to the python script ?
https://github.com/bitcraze/crazyflie-l ... er_push.py
Could you check if the multiranger is working by checking the logplotter in the cfclient?
Could you check if the flowdeck works by checking the cfclient (same as the multiranger), and try out motion_commander_demo.py?
