X Mode
ssozonoff
X Mode
Post by ssozonoff »
Has anyone tried X Mode lately, I checked the box but it seems to have no effect ?
Thanks,
Serge
TheFrog4u
Re: X Mode
Post by TheFrog4u »
hmm.. works fine for me.. which version are u using?
ssozonoff
Re: X Mode
Post by ssozonoff »
cfclient-2013.4.2
And latest firmware.
Serge
TheFrog4u
Re: X Mode
Post by TheFrog4u »
I am not using the installer version, but repositories.. however this version still should work (anyone can confirm this issue?)
..When u check that box, what does the python console say? It should print: "INFO:cfclient.ui.tabs.FlightTab:Clientside X-mode enabled: True"
ssozonoff
Re: X Mode
Post by ssozonoff »
TheFrog4u wrote:It should print: "INFO:cfclient.ui.tabs.FlightTab:Clientside X-mode enabled: True"
It sure does but nothing changes with regards to the way it flies...
Serge
Re: X Mode
ssozonoff wrote:It sure does but nothing changes with regards to the way it flies...Serge
Hmm, that's strange. The client-side X-mode should work with any firmware since the client will transform the set-points for roll/pitch so the platform will orient itself like an X. If you look at this image you can see the "front" orientation of the platform in X-mode. So if you only change the pitch the platform should not move towards M1 but instead diagonally between M1 and M4.
ssozonoff
Re: X Mode
Post by ssozonoff »
I agree with everything you are saying sadly its not what I am observing....
I will keep testing.
Thanks,
Serge
ssozonoff
Re: X Mode
Post by ssozonoff »
OK,
Seems if I change some of the other parameters it works ....
Serge
Re: X Mode
Sounds like a bug. So if you just change focus to something else (without changing any value) does it work then?
ssozonoff
Re: X Mode
Post by ssozonoff »
marcus wrote:Sounds like a bug. So if you just change focus to something else (without changing any value) does it work then?
Seems like the value has to change..
Serge
