crazyradiopa scan
ampf
crazyradiopa scan
Post by ampf »
Hi
I was trying to run a scan with crazyradiopa on kali linux in a raspberry 3 b+ but it returns me the message
-attacks are disable
-cannot find crazyradio pa usb dongle
-please make sure you haveit preloaded with the mouse jack firmware
I tried tounplug and plug again the dongle but the result is the same
How can I bypass this?
Re: crazyradiopa scan
I do not know much about the mousejack/research firmware and this forum is mostly about Crazyflie and Crazyradio used to control the Crazyflie so it is likely people on this forum will not be able to help much. I suggest you ask on the github issue tracker of mousejack/research firmware.
