Hello everyone,
I am new in using the crazyflie loco positionning system and I used six anchors for the loco positioning system. I want to known how can I use my Loco Positioning System to achieve hover test?
Thank's a lot for your help!!!
hover
Re: hover
After folowing the getting started guide for LPS you can follow this guide that will show you how to make your Crazyflie hover in LPS: https://www.bitcraze.io/getting-started ... ition-hold.
Re: hover
Yes you can hover using a python script, the easiest example to start from is most likely the motion commander demo: https://github.com/bitcraze/crazyflie-l ... er_demo.py.
lcmiao
Re: hover
Hi Arnaud,
Thanks for your reply! But When I run the motion commander demo: https://github.com/bitcraze/crazyflie-l ... er_demo.py, An error has appeared: ‘File"C:\Users\DELL\Desktop\crazyflie-lib-python-master\examples\position_commander_demo.py", line 37, in <module>
from cflib.positioning.position_hl_commander import PositionHlCommander ModuleNotFoundError: No module named 'cflib.positioning.position_hl_commander'’.
But in cflib\positioning I can find ‘position_hl_commander.py’.
Do you know how I can fix this error?
