FLOWDECK2
RyanMco
FLOWDECK2
Hi guys, what's up?
I'm new on the world of nano crazyflie(fpv) and I'm stuck on how can I connect my FLOWDECK2 onto my crazyflie?
I've the device "flowdeck2" but how can I connect it onto my crazyflie and what I do for configure it on my firmware ?!
thanks alot
thanks alot
RyanMco
Re: FLOWDECK2
If there's any link illustrate step by step how can I connect it, it would be much appreciated .
coreysnipes
- Contact:
Re: FLOWDECK2
These two should get you going.
first: https://www.bitcraze.io/getting-started ... ion-decks/
and then: https://www.bitcraze.io/getting-started-with-flow-deck/
RyanMco
Re: FLOWDECK2
but there's no infromation about how do I wire my flowdeckV2 hardware (not in aspect of software) on my crazyflie !!coreysnipes wrote: ↑Wed Apr 10, 2019 2:07 am These two should get you going.
there's no schematic of how do I wire from flowdeckV2 to my drone ..
coreysnipes
- Contact:
Re: FLOWDECK2
Hm, maybe I'm missing something. You don't need to wire or solder anything. You should have some of these deck connectors (a short pair, and a long pair) which attach to the bottom of the CF. https://store.bitcraze.io/collections/s ... -connector
Then you press the flow deck onto those, and it makes all the necessary electrical connections. Make sure you have the correct side facing the CF, and it is pointing the right way.
coreysnipes
- Contact:
Re: FLOWDECK2
This has a quick display of attaching the flow deck, at the beginning. https://www.youtube.com/watch?v=bGvt6Nwja3E
RyanMco
Re: FLOWDECK2
what do you mean with "pointing on the right way" ?!coreysnipes wrote: ↑Wed Apr 17, 2019 12:08 am Hm, maybe I'm missing something. You don't need to wire or solder anything. You should have some of these deck connectors (a short pair, and a long pair) which attach to the bottom of the CF. https://store.bitcraze.io/collections/s ... -connector
RyanMco
Re: FLOWDECK2
I have bought these deck connectors yesterday and I I attached my flowdeckv2 on it, so what do I do write now? how do I know if it's work or not? which steps of firmware should I follow?! is there any specific software should I use with my flowdeckv2?! thanks!!
Re: FLOWDECK2
Hi, there is a getting started guide that should get you up and running with the flow deck: https://www.bitcraze.io/getting-started-with-flow-deck/. Once you are flying, you can follow this getting started if you want to program autonomous flight: https://www.bitcraze.io/getting-started ... ne-bundle/.
RyanMco
Re: FLOWDECK2
But why I need the second link if I'm using remote?! I mean why I need python client if I use my remote?!
