Hi everyone!
I am using the qualisys tab of the cfClient and want to know if there is a away to make the drone spin on the z axis but also move around?
https://www.jaycar.com.au/obstacle-avoi ... r/p/GT4244
is it possible to have it move around like in the link above using the qualisys motion capture system?
Purposefully spinning on Z axis
cafeciaojoe
- Member
Re: Purposefully spinning on Z axis
If is unfortunately not possible in the client. It is technically possible but not implemented.
If you want to do things like this, you should maybe consider to write your own python script instead of using the Qualisys tab.
