Hello I am a computer science Masters student, I was working on a project for a specific scenario where it includes communication between 2 crazyflies.
1. Basically When the battery of drone-A is going down, I want to trigger drone-B to start flying.
2. Here I need to pass the geo-position and of the drone-A to drone-B. so drone-B can take in that position.
I wanted to know the ways I can have communication between 2 drones and pass msgs.
Thank you
Communication between 2 crazyflies and message passing
Rohit Gowda
Yoyasp
Re: Communication between 2 crazyflies and message passing
Easiest way i can think off is to use the PA dongle and let both drones communicate via your basestation/computer.
Set up a log variable on drone A to monitor the battery level, aswell as its position.
When the battery level reaches a certain threshhold give a command to drone B to fly to the last known location where the battery was not low.
I agree with @Yoyasp, while the Crazyflie hardware is capable of implementing direct communication between Crazyflies, nothing is implemented right now and the implementation would be much harder than passing by the base-station.
We have been thinking lately about adding a simple packet API that would allow the STM32 to send and receive raw packets, I created a ticket to explain the idea but I will most likely not have time to look at it soon, so any comment/help is welcome if anyone wants to poke in the nRF51
Rohit Gowda
Thank you for the reply.
Actually this is just an example scenario,
The main idea is to have a communication between two crazyflie quadcopters without the use of basestation.
1. Drone A tries to communicate with drone B by broadcast or 1-1.
2. And drone b acknowledges.
SnakeWayne
it looks like some one has already done this. In https://ieeexplore.ieee.org/abstract/document/8461176/ they use token ring to enable communication between multi cfs. You can get the detail if you can contact the authors :)
