I've assembled my Crazyflie and checked props and motors cable (see pictures)
I'm using this controller http://www.realflight.com/basic.html
But Crazyflie does'nt fly because thrust go to 55% max
Someone can help me ?
[SOLVED] drone does'nt fly :(
foosel
- Contact:
Re: drone does'nt fly :(
The propellers on M1 and M3 are upside down and of the wrong orientationm that's why your drone won't fly. See also here. Remove them (careful with that) and use the ones from the other package included with your kit that have the curve on the other side. Make sure that the "hollowed out" part of the propeller is always facing downward.
blondie63
ok now fly
thanks..
but, maybe wiki can be enhance adding: cw props (M2 and M4) with label A
foosel
- Contact:
The wiki already states, in the assembly instructions, step 9, what prop to mount on which motor, what way they are supposed to be facing, to look for the A, that they come separated by direction in two different packs.
What is unclear there?
blondie63
Re: [SOLVED] drone does'nt fly :(
you are right ! sorry...
it's very clear, but really i've not read all steps
