[SOLVED] Crazyflie ROS Stack "cmake failure"
HuzayfaaN
Post by HuzayfaaN »
Hi All,
I am attempting to setup the crazyfle software on a Linux system running ubuntu 16.04 LTS and ROS Kinetic.
As I am quite so unfamiliar with the operating system itself and also ROS, I have therefore done some background research and familiarised myself with the basics. Now, I am utilising one particular publication to download the crazyflie software and get it running on my PC. However I have ran into an error which I don't entirely understand or know how to go about fixing.
I am using this publication ("Flying Multiple UAVs Using ROS" - http://act.usc.edu/publications/Hoenig_ ... OS2017.pdf) to help support the setup of the software. I have, so far, successfully completed the instructions up until and including section 3.3. When executing the following commands as part of section 3.4
$ git clone https://github.com/whoenig/crazyflie_ros.git
$ cd ~/crazyflie_ws
$ catkin_make
I encounter the following error message in the command window
Base path: /home/huzayfaa/crazyflie_ws
Source space: /home/huzayfaa/crazyflie_ws/src
Build space: /home/huzayfaa/crazyflie_ws/build
Devel space: /home/huzayfaa/crazyflie_ws/devel
Install space: /home/huzayfaa/crazyflie_ws/install
#### Running command: "cmake /home/huzayfaa/crazyflie_ws/src -DCATKIN_DEVEL_PREFIX=/home/huzayfaa/crazyflie_ws/devel -DCMAKE_INSTALL_PREFIX=/home/huzayfaa/crazyflie_ws/install -G Unix Makefiles" in "/home/huzayfaa/crazyflie_ws/build"
-- Using CATKIN_DEVEL_PREFIX: /home/huzayfaa/crazyflie_ws/devel
-- Using CMAKE_PREFIX_PATH: /opt/ros/kinetic
-- This workspace overlays: /opt/ros/kinetic
-- Using PYTHON_EXECUTABLE: /usr/bin/python
-- Using Debian Python package layout
-- Using empy: /usr/bin/empy
-- Using CATKIN_ENABLE_TESTING: ON
-- Call enable_testing()
-- Using CATKIN_TEST_RESULTS_DIR: /home/huzayfaa/crazyflie_ws/build/test_results
-- Found gmock sources under '/usr/src/gmock': gmock will be built
-- Found gtest sources under '/usr/src/gmock': gtests will be built
-- Using Python nosetests: /usr/bin/nosetests-2.7
-- catkin 0.7.14
-- BUILD_SHARED_LIBS is on
-- ~~ traversing 5 packages in topological order:
-- ~~ - crazyflie (metapackage)
-- ~~ - crazyflie_description
-- ~~ - crazyflie_demo
-- ~~ - crazyflie_controller
-- ~~ - crazyflie_driver
-- +++ processing catkin metapackage: 'crazyflie'
-- ==> add_subdirectory(crazyflie_ros/crazyflie)
-- +++ processing catkin package: 'crazyflie_description'
-- ==> add_subdirectory(crazyflie_ros/crazyflie_description)
-- +++ processing catkin package: 'crazyflie_demo'
-- ==> add_subdirectory(crazyflie_ros/crazyflie_demo)
-- +++ processing catkin package: 'crazyflie_controller'
-- ==> add_subdirectory(crazyflie_ros/crazyflie_controller)
-- Using these message generators: gencpp;geneus;genlisp;gennodejs;genpy
-- +++ processing catkin package: 'crazyflie_driver'
-- ==> add_subdirectory(crazyflie_ros/crazyflie_driver)
CMake Warning at /opt/ros/kinetic/share/catkin/cmake/catkinConfig.cmake:76 (find_package):
Could not find a package configuration file provided by "crazyflie_cpp"
with any of the following names:
crazyflie_cppConfig.cmake
crazyflie_cpp-config.cmake
Add the installation prefix of "crazyflie_cpp" to CMAKE_PREFIX_PATH or set
"crazyflie_cpp_DIR" to a directory containing one of the above files. If
"crazyflie_cpp" provides a separate development package or SDK, be sure it
has been installed.
Call Stack (most recent call first):
crazyflie_ros/crazyflie_driver/CMakeLists.txt:7 (find_package)
-- Could not find the required component 'crazyflie_cpp'. The following CMake error indicates that you either need to install the package with the same name or change your environment so that it can be found.
CMake Error at /opt/ros/kinetic/share/catkin/cmake/catkinConfig.cmake:83 (find_package):
has been installed.
-- Configuring incomplete, errors occurred!
See also "/home/huzayfaa/crazyflie_ws/build/CMakeFiles/CMakeOutput.log".
See also "/home/huzayfaa/crazyflie_ws/build/CMakeFiles/CMakeError.log".
Invoking "cmake" failed
I have also attached the two files that the code above refers to.
I would very much appreciate any help. Thank in advance for your time and support! :)
Thanks,
Huzayfaa
p.s. if this matter should have been posted elsewhere please let me know and I'd be more than happy to remove the post from here and re-post it under a different forum - sorry.
CMakeOutput.log
(41.84 KiB) Downloaded 510 times
CMakeError.log
(2.71 KiB) Downloaded 470 times
whoenig
Re: Crazyflie ROS Stack "cmake failure"
Post by whoenig »
The book chapter is a bit outdated. You will need to initialize and update the git submodules, see https://github.com/whoenig/crazyflie_ros#installation for the updated instructions.
For crazyflie_ros related problems, it is best to open an issue on github to get help.
HuzayfaaN
Post by HuzayfaaN »
Thanks for the prompt reply.
I have followed the updated instructions and have managed to get it working - Thanks!
Regards,
Huzayfaa
