Multi-Ranger left sensor [FAIL]
placebo
Post by placebo »
I got the CF STEM Ranging bundle over the holidays and have been trying to get it working. I successfully completed the getting-started-with-the-crazyflie-2-0 tutorial but I got stuck on the getting-started-with-stem-ranging-bundle tutorial; when I run the script the CF connects (i.e. the GREEN LED for both the CF and CrazyRadio are ON.) but it just sits there motionless.
I began investigating and came across a number of strange issues. I've been able to solve most of the issues via existing posts on these forums so I thank you all for that. There are still a few problems that I've not been able to solve though. One in particular is with the Multi-Ranger (MR) deck. When I power on the CF with (or without) the MR deck connected, the self-test passes as expected. However, after the self-test, with the MR deck connected, both BLUE LED's are ON but the RED LED flashes 5 or 6 times for about 1 second and then OFF for 1 second. Rinse and repeat. I can still connect to the Crazyflie Client. Here is the output from the main menu, Help -> About -> Debug:
Cfclient
Cfclient version: 2018.12
System: linux
Python: 3.6.8
Qt: 5.11.2
PyQt: 5.11.3
Interface status
radio: Crazyradio version 0.53
serial: None
udp: None
UsbCdc: No information available
Input readers
linuxjsdev (0 devices connected)
Input devices
None
Crazyflie
Connected: radio://0/80/2M
Firmware: a203d748e139 (MODIFIED)
Sensors found
BMP388: 0
HMC5883L: 1
MS5611: 1
Sensors tests
MPU6500: 1
HMC5883L: 1
MS5611: 1
The fact that BMP388 equals 0 and the other sensors all equal 1 seems fishy. However, this is the case regardless of which decks, if any, are mounted. From the console tab:
SYS: Build 0:a203d748e139 (2018.12) MODIFIED
SYS: I am 0x2035355237485008002C0041 and I have 1024KB of flash!
CFGBLK: v1, verification [OK]
DECK_DRIVERS: Found 16 drivers
DECK_INFO: Found 2 deck memories.
DECK_CORE: 2 deck enumerated
ZR2: Z-down sensor [OK]
MPU9250 I2C connection [OK].
AK8963 I2C connection [OK].
LPS25H I2C connection [OK].
ESTIMATOR: Using estimator 2
CONTROLLER: Using controller 1
EEPROM: I2C connection [OK].
AK8963: Self test [OK].
DECK_CORE: Deck 0 test [OK].
MR: Init front sensor [OK]
MR: Init back sensor [OK]
MR: Init up sensor [OK]
MR: Init left sensor [FAIL]
MR: Init right sensor [OK]
DECK_CORE: Deck 1 test [FAIL].
The only obvious issue here is the failing left sensor. Does this mean I have a bad MR deck or could it be something else?
Re: Multi-Ranger left sensor [FAIL]
Hi and welcome to the forum!
As can be seen in the log the left ranging sensor seam to fail. Most likely a solder problem. Fastest way to fix would be to heat up the solder that solders the small adapter board. Do it one by one and around 3 sec on each. If that doesn't work send us an email, support(at)bitcraze.io and we will arrange a replacement.
placebo
Post by placebo »
I will do that. Just to be clear, the left sensor is on the port side and the right sensor is on the starboard side. Yes?
Yes exactly. It's the one with the bitcraze.io text beside it.
placebo
[SOLVED] Multi-Ranger left sensor [FAIL]
Post by placebo »
I'm actually kind of surprised, but reflowing the 5 solder welds on the failing sensor worked. :D :D :D Well, at least I can now run the STEM ranging demo. Now I just need to figure out why that BMP388 is returning a 0 status code and if that is even a problem. The BMP388 isn't mentioned anywhere in the documentation or the forums. I looked it up and it's a digital pressure sensor but for what?
Great! A solder might have cracked during shipping or the manufacturer did not do their job :oops: . Just let us know if you run into problems again.
As for the BMP388 it is a bit confusing and the "about->debug" output is not fully accurate anymore. The BMP388 is actually not on the CF2.0 but on the CF2.1. The CF2.0 has the LPS25H barometer. You can disregard this information and I will create a bug report on github to fix this information.
placebo
Post by placebo »
There's a CF2.1? Is it beta?
CF2.1 is to be released during Q1 2019. You can read a bit about it in this blog post.
wydmynd
Post by wydmynd »
thanks for this post! I got 5 multi ranging decks and now testing a new one and it says right sensor failed!
so will try to reflow.
also, I had one multi ranger fail completely, but that was due toa crash, replacing the 0.1" headers to new ones fixed the issue.
dlitz
Post by dlitz »
I'm having a similar issue. I resoldered the connection, which gives me an [OK] on startup, but the range value of the left sensor seems to always be 65535 (or something close to that; I haven't looked at the numeric value, just the graph). The other sensors still appear to work. I did crash it a few times when attempting to use assisted flight, but I'm not sure whether it was working before, or whether the instability was the result of a bad sensor.
I've ordered another multi-ranger board, but I wonder is it possible to disable just that one sensor, so that its output is not used for estimating position?
