has anyone used this repository before?
https://github.com/qualisys/crazyflie-resources
My understanding is that you can fly a crazyflie using the qualisys system without crazyswarm and ROS. I am getting the following issue:
Getting the following error when trying to run example-simple-hover.py:
~ Qualisys x CrazyFlie ~
Connecting to radio://0/80/2M
Connected to QTM, version Version set to 1.17
Getting parameters from QTM...
Starting to record new measurement in QTM...
Starting listening to QTM packet stream...
Found 1 6DoF bodies defined in QTM project: Terminating due to error receiving QTM parameters: string indices must be integers
Windows 10 with Anaconda3, using QTM 1.0.1, cflib 0.1.6, xmltodict 0.11.0
We're able to establish a connection to the aircraft using the crazyflie PC client, so there's no problem with the radio or the aircraft.
If we modify line:
qtmRigidbodies_idxByName[body['Name']] = i
to read:
qtmRigidbodies_idxByName[body] = i
we get the error:
Got link error callback [Too many packets lost] in state [1] Connection to radio://0/80/2M failed: Too many packets lost Terminating due to error while initializing flight controller: Too many packets lost
Any idea on how to fix this?
Cheers
The Qualisys x Crazyflie resources repository
cafeciaojoe
- Member
Re: The Qualisys x Crazyflie resources repository
I don't have that much knowledge about the Qualisys library, you might be best off posting an issue on their github. My guess though is that the python excepts/hangs and thus drops the connection when you try do to the call. So something is probably wrong with the "qtmRigidbodies_idxByName[body] = i" call.
