Cannot connect to radio from cfclient
aebatirel
Post by aebatirel »
When I try to connect to cfclient in firmware mode the client doesn't sees the drone but when I put it in the bootloader mode or ıf I plug it via usb in firmware mode it sees it. Also I can connect from an iOS device as a controller. So I'm pretty sure it is not a hardware issue. I'm using mac version of the client.
Re: Cannot connect to radio from cfclient
Could the CF2 be on a different address? Try connecting it using USB, then you can go to the configuration and set address to the default one 0xE7E7E7E7E7.
