Hi CF World,
We have been publishing direct PWM values for our rl project here: https://sites.google.com/berkeley.edu/mbrl-quadrotor/. But, when doing open loop takeoff we find that the flight path is substantially different with the same PWM values across different runs. Anyone experience something similar? This is going from 0 motor voltage to a set value. Sometimes will go straight up and sometimes will veer to positive pitch for example.
Publishing Identical PWMs with Differing Performance
natolambert
Re: Publishing Identical PWMs with Differing Performance
Very exiting stuff you are working on, we look forward to seeing the outcome!
I have no idea how predictive a takeoff would be by just sending PWM values. First thing, how are you setting the PWM values? Any chance they ate not set at the same time?
If you have some code to share we could do some quick tests here to see what result we get.
