how to create a config.mk file
Discussions about technology in general
zjc515484158
Post by zjc515484158 »
hello dear friends, I have updated the firmware-master programming in virtual machine. Now i want to enable the BQD. Because I lack MCU programming knowledge, so i can't create a config.mk file in root directory. Or I didn't find it? Can anyone help me to solve this problem? THANK YOU VERY MUCH!! :oops:
Re: how to create a config.mk file
config.mk is in the folder tools/make/ you can copy the existing tools/make/config.mk.sample into tools/make/config.mk to get a starting point.
Each time you modify this file you will most likely need to "make clean" and "make" the full project in order for the changes to be taken into account.
