Source Code Location?
marhar
Post by marhar »
I saw in one of the announcements that this will be an open-source project.
Any pointers to where the source code will be, and estimated release date?
Re: Source Code Location?
The source code is at https://bitbucket.org/bitcraze
It is still missing some pieces but everything should be uploaded during the weekend
ataraxic
Post by ataraxic »
are you planning to have git repository?
scio me nihil scire
umrashrf
Post by umrashrf »
"This is git hosted on Bitbucket."
My bad didn't know Mercurial was there as well.
This is actually mercurial repos. We are not planing on switching to Git as mercurial suits our needs. The mercurial work-flow is very similar to git.
If you really cannot get used to mercurial it is still possible to work with git while pushing/pulling to mercurial: http://stackoverflow.com/questions/8834 ... repository
mikevoyt
Post by mikevoyt »
Have you disabled pull requests? I fixed something with the Crazyflie PC client (to use 'type'-'id' as the key for inputMap dictionary, so that we can map a button and an axis with the same id), and attempted a pull request, but get "Access denied".
thanks,
-mike
Hi Mike,
Great! No, we haven't changed the settings for the pull-request since we got the last pull-request for the pc client.
/Marcus
Arjumand
Post by Arjumand »
Great, I think we have our first community development started. I'm not the python and PC expert so I hope Arnaud or Marcus will jump in. I know Arnaud quickly tested the cfclient on OSX but had problems with the joystick driver. Other then that I think it worked pretty easily.
Implementing what you want should not be any problem as long as you can translate the commands into roll, pitch, yaw and thrust.
Arjumand
