[SOLVED] Crazyflie cannot fly, ERROR! Older timer found
luisruiz
Post by luisruiz »
I have a Crazyflie, I already followed the installation intructions. I have the following:
-- A 10 DOF CrazyFlie assembled, I guess it is well assembled, since when I turn it on the rotors turn in the right directions and the leds blink as described.
-- Crazyflie PC Client running on Windows 7.
-- I have installed Microsoft Visual Studio 2012 for Desktop.
-- I am using an Elecom PS3 like controller.
-- Crazyradio installed.
So, this is happening:
-- I open the PC client
-- Click on connect
-- The client shows:
radio://0/10/250K
debug://0/0 - Debugdriver for UI testing
-- At this point if I click scan, the green led on the Crazyflie blinks, that makes me think the Crazyradio is working right.
-- I click connect.
After connecting I am not able to fly the Crazyflie. The controller is responding since I move the joysticks and I can see the target values moving accordingly to the controller configuration.
Then looking at the output window I always get the same messages, which are below, I get an error related to an old timer and a warning related to an stabalizer.roll, but I cannot find the cause of them, can anyone help me??
Thanks!!!
--Luis
Info: Using config path: C:\Users\wanglab\AppData\Roaming\cfclient
Info: sys.path= ['C:\\Program Files (x86)\\Crazyflie client', 'C:\\Users\\wanglab\\AppData\\Roaming\\cfclient', 'C:\\Program Files (x86)\\Crazyflie client\\.']
INFO:cfclient.utils.config:Dist config read from C:\Program Files (x86)\Crazyflie client/cfclient/configs/config.json
INFO:cfclient.utils.config:Config file read from [C:\Users\wanglab\AppData\Roaming\cfclient/config.json]
INFO:cfclient.utils.input:Parsing [ELECOM.json]
INFO:cfclient.utils.input:Parsing [Generic_OS_X.json]
INFO:cfclient.utils.input:Parsing [PS3_Mode_1.json]
INFO:cfclient.utils.input:Parsing [PS3_Mode_2.json]
INFO:cfclient.utils.input:Parsing [xbox360_mode1.json]
INFO:cfclient.utils.logconfigreader:Parsing [stabalizer.json]
INFO:cfclient.ui.tabs.FlightTab:Changed flightmode to Normal
Saving Elecom Wireless Gamepad
INFO:cflib.crtp.radiodriver:v0.5 dongle with serial N/A found
*************** AT THIS POINT I HAVE SCANNED THE CRAZYFLIE AND AFTER IT I CLICK CONNECT ***********************
INFO:cflib.crazyflie:Callback->Connection initialized[debug://0/0]
INFO:cflib.crazyflie:We are connected[debug://0/0], request connection setup
INFO:cflib.crtp.debugdriver:TOC access on port 5
INFO:cflib.crtp.debugdriver:TOC[5]: Requesting TOC CRC, sending back fake stuff: 15
INFO:cflib.crazyflie:Callback->Connected to [debug://0/0]
INFO:cflib.crtp.debugdriver:TOC access on port 2
INFO:cflib.crtp.debugdriver:TOC[2]: Requesting TOC CRC, sending back fake stuff: 15
INFO:cflib.crazyflie:Callback->Connection setup finished [debug://0/0]
INFO:cflib.crtp.debugdriver:LOG:Adding block id=1
INFO:root:FakeDataLoggingThread created for blockid=1
INFO:cflib.crtp.debugdriver:LOG:Adding block id=2
INFO:cflib.crtp.debugdriver:LOG:Starting block 1
INFO:root:FakeDataLoggingThread created for blockid=2
INFO:root:_FakeLoggingDataThread: Enable thread [Fakelog block=1] at period 0
INFO:cflib.crtp.debugdriver:LOG:Started block=1
INFO:cflib.crtp.debugdriver:LOG:Adding block id=3
INFO:root:FakeDataLoggingThread created for blockid=3
INFO:cflib.crtp.debugdriver:LOG:Adding block id=4
INFO:root:FakeDataLoggingThread created for blockid=4
INFO:cflib.crazyflie.log:Have successfully logging for block=1
INFO:cflib.crtp.debugdriver:LOG:Starting block 2
INFO:cflib.crtp.debugdriver:PARAM: Getting value for 1
INFO:root:_FakeLoggingDataThread: Enable thread [Fakelog block=2] at period 0
INFO:cflib.crtp.debugdriver:LOG:Started block=2
INFO:cflib.crtp.debugdriver:LOG:Starting block 3
INFO:cflib.crtp.debugdriver:PARAM: Getting value for 0
INFO:root:_FakeLoggingDataThread: Enable thread [Fakelog block=3] at period 0
WARNING:cflib.crazyflie:ExpectAnswer: ERROR! Older timer whas running while scheduling new one on [2]
INFO:cflib.crtp.debugdriver:LOG:Started block=3
INFO:cflib.crtp.debugdriver:LOG:Starting block 4
INFO:cflib.crtp.debugdriver:PARAM: Getting value for 5
INFO:root:_FakeLoggingDataThread: Enable thread [Fakelog block=4] at period 0
INFO:cflib.crtp.debugdriver:LOG:Started block=4
INFO:cflib.crtp.debugdriver:PARAM: Getting value for 4
INFO:cflib.crazyflie.log:Have successfully logging for block=2
INFO:cflib.crtp.debugdriver:PARAM: Getting value for 6
INFO:cflib.crazyflie.log:Have successfully logging for block=3
INFO:cflib.crtp.debugdriver:PARAM: Getting value for 2
INFO:cflib.crtp.debugdriver:PARAM: Getting value for 7
INFO:cflib.crazyflie.log:Have successfully logging for block=4
INFO:cflib.crtp.debugdriver:PARAM: Getting value for 3
INFO:cflib.crtp.debugdriver:PARAM: Getting value for 11
INFO:cflib.crtp.debugdriver:PARAM: Getting value for 10
INFO:cflib.crtp.debugdriver:PARAM: Getting value for 12
INFO:cflib.crtp.debugdriver:PARAM: Getting value for 8
INFO:cflib.crtp.debugdriver:PARAM: Getting value for 13
INFO:cflib.crtp.debugdriver:PARAM: Getting value for 9
INFO:cflib.crtp.debugdriver:PARAM: Getting value for 14
INFO:cflib.crtp.debugdriver:PARAM: Getting value for 15
WARNING:cflib.crazyflie.toc:Unable to find variable [stabalizer.roll]
WARNING:cflib.crazyflie.log:Log: stabalizer.roll not in TOC, this block cannot be used!
WARNING:cfclient.ui.tabs.PlotTab:Could not setup log configuration!
*************** I CANNOT MAKE IT FLY, THEN I CLICK DISCONNECT ***********************
INFO:cflib.crazyflie:Closing link
INFO:cflib.crtp.debugdriver:Closing debugdriver
INFO:cflib.crazyflie:Callback->Disconnected from [debug://0/0]
Re: Crazyflie cannot fly, ERROR! Older timer found
I think it might be software mismatch. Can you try updating to the most recent versions.
Also make sure the red led is blinking about 2 times a second. That means it is calibrated and ready to fly. If it is only blinking once a second it is not calibrated and won't fly.
Before you click Connect you should select the row that says "radio://0/10/250K". Looking at the log you attached you are connecting to the other URI, the "debug://0/0" and using this you cannot fly (this is only for debug purposes).
/Marcus
luisruiz
Post by luisruiz »
I was not selecting "radio://0/10/250K" before conecting. Now it is flying, thanks!
--Luis
totzkie81392
Re: [SOLVED] Crazyflie cannot fly, ERROR! Older timer found
Post by totzkie81392 »
i cannot see the URI when conneting to crazyflie..anyone knows how to solve this problem?
pls help..its for educational purpuses..thank you
The Crazyradio driver is probably not working. If you open the bootloader dialog in the cfclient do you get an error for the Crazyradio shown besides the status:?
If you will use it for educational purposes I suggest you start out with the virtual machine as it will get you going quickly.
