Is it possible to send commands for thrust, yaw, roll and pitch for certain intervals of time through the client??
Regards
AG
Sending commands through client
Re: Sending commands through client
It is possible using the ZMQ interface. You can find some documentation for it on the wiki: https://wiki.bitcraze.io/doc:crazyflie: ... put_device.
Abanoub.G
How would I enable the zmq from the client??
Abanoub.G
Also in one of the examples in your VM where the CF is ramed using the zmq, it needs to import at zmq file that is not included. I have looked up a lot on the internet but it's really confusing to get it working.
The zmq files that I have managed to get from the web are missing a subfolder called context thus the code keeps on giving me errors. Is it possible if you upload the zmq file you guys are using in your VM.
Abanoub.G
Right I have managed to install zmq by following the steps on this website https://tuananh.org/2015/06/16/how-to-i ... on-ubuntu/
However, I am still getting this error of 'module' object has no attribute 'Context'
i.e. there is nothing called context inside of the zmq folder
I am assuming you want to write scripts in python. You should be able to get started with "pip3 install zmq", this will install the zmq module for python and will allow you so connect the client zmq socket. There should be no need to compile anything manually. If zmq is installed, Context is there:
Have you managed to enable the zmq commander in the client? It is disabled by default but can be enabled in the config json file as documented in the wiki page. You can find the configuration folder by opening the menu "settings/open config folder" in the client.
$ python3
Python 3.5.2 (default, Nov 23 2017, 16:37:01)
[GCC 5.4.0 20160609] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import zmq
>>> zmq.Context
<class 'zmq.sugar.context.Context'>
Hi, I though I would make a quick example to get you started.
This will set the thrust to 20% in the client:
You should be able to see the thrust setpoint changing in the client.
$ python3
>>> import zmq
>>> context = zmq.Context()
>>> socket = context.socket(zmq.PUSH)
>>> socket.connect("tcp://localhost:1212")
>>> command = {"version": 1, "client_name": "test", "ctrl": { "roll": 0.0, "pitch": 0.0, "yaw": 0.0, "thrust": 20.0}}
>>> socket.send_json(command)
