Hi guys,
I followed the beginners guide here:
https://www.bitcraze.io/getting-started ... /#charging
But, when I charge it on USB or plug, the blue left LED is not blinking for me. It's still charging, but it's just bright.
What's your tip ?
Best
Florian
[SOLVED] No blinking on charging
benno208
Re: No blinking on charging
You might be hitting a bug where the battery indication does not start at startup. Does it starts blinking if you remove and re-insert the USB connector while the Crazyflie is ON.
prbhtkm
Re: [SOLVED] No blinking on charging
After re-inserting the USB connector, it started blinking. Thanks.
