After powering the CF on and trying to connect to client nothing happens unless I shake my crazyflie. Only then I start seeing some feedback in the client. Then the horizon looks all wrong (of course) and the CF is very hard to control. What could the reason for this be? I assembled my CF yesterday evening and wanted to start flying it tonight.
My setup: Xbox360 wireless controller on osx 10.8. I've flashed the CF firmware to the latest and here's the log from the console (client):
SYS: I am 0x8711415054568549672FF50 and I have 128KB of flash!
MPU6050: Self test [OK].
HMC5883L: Self test [OK].
MS5611: Self test [OK].
I get some other errors in the terminal from the client:
NFO:cflib.crazyflie.log:Have successfully logging for block=9
WARNING:cflib.crazyflie:ExpectAnswer: ERROR! Older timer whas running while scheduling new one on [2]
WARNING:cflib.crazyflie.log:Error when adding blockId=14, should tell listenders...
WARNING:cflib.crazyflie.log:Error when adding blockId=15, should tell listenders...
INFO:cflib.crazyflie.log:Have successfully logging for block=10
INFO:cflib.crazyflie.log:Have successfully logging for block=11
INFO:cflib.crazyflie.log:Have successfully logging for block=12
INFO:cflib.crazyflie.log:Have successfully logging for block=13
Have to shake CF to connect to CR
dwroblewski
- Contact:
Re: Have to shake CF to connect to CR
Do you shake the Crazyflie directly after powering it on? If so then that explains the strange behavior.
If you just place it on a stable surface, power it on and press the Connect button in the UI do you find any URIs except for debug://0/0?
TheFrog4u
Shaking indicates an defective contact somewhere.. or your Accelerometer is very noisy.. or you having heavy interfearence with a wifi.
I would try:
1: Dont shake it after conect
2: You could try using this firmware from DesTinY to check your accelerometer and propellers
3: Try setting the bandwith to 1Mbit and choose another channel
I would try:
