Communication between two CrazyRadios
Limnfo
Post by Limnfo » Sat Dec 09, 2017 6:33 pm
Hi there!
as stated in the following post, in 2015 it was not possible to "connect" two crazyradios together
arnaud wrote:
Tue Apr 14, 2015 6:37 am
And communicating between two Crazyradio is not yet possible, Crazyradio is not listening to the radio, only transmitting (there is a pull request for making it listen in the repos so it is comming though)
Has somebody made this possible in the meantime? I would be highly interested if I could enable communication between a PC and a Raspberry via crazyradio.
Best regards,
Limnfo
Re: Communication between two CrazyRadios
Post by arnaud » Tue Dec 12, 2017 9:31 am
There is now a PRX mode in the Crazyradio firmware git repos, it should be what you need to communicate between two Crazyradios. Though I have not tested it personally so I am not sure of the state of it.
Limnfo
Post by Limnfo » Tue Jan 02, 2018 9:52 pm
Hi arnaud,
thanks for your reply!
Is there someone who may know it, or someone I could ask for details?
It would be really great if this would work :-)
Post by arnaud » Mon Feb 12, 2018 4:11 pm
I just tested the PRX functionality in the latest commit and it works. If you compile the firmware from source, and use the prx and ptx examples from the crazyradio-firmware repos, you can communicate between two Crazyradios on two different computers
See my message in another thread for the mandatory warnings about compiling your own firmware :-).
