SYS: I am 0x8711205354568549671FF50 and I have 128KB of flash!
IMU: HMC5883L I2C connection [FAIL].
IMU: MS5611 I2C connection [FAIL].
MPU6050: Self test [OK].
Can anyone tell me what/why those two tests are failing?
[SOLVED] IMU: HMC5883L I2C connection [FAIL]
EverInfinity
skube
- Member
Re: IMU: HMC5883L I2C connection [FAIL]
Do you have the 6-DOF version of the Crazyflie? If so, that would explain it.
Crazyflie Nano 10-DOF | AR Drone v1 | MikroKopter Okto
EverInfinity
Hehe >_>
Yes...thank you!
Yes...thank you!
I have realizes that this printout might be a bit misleading. We should probably change it to [UNAVAILABLE] instead of [FAIL].
