Cannot turn crazyflie 2.0 off
viotheapple
Post by viotheapple »
Hi there,
For some reason, I cannot turn my crazyflie off. Only the M2 light is flashing in blue at around 3 times per second and I think it might be in firmware mode? I tried to press the power button both for a short and long period of time, but it seems like the quadcopter just won't shut off. Does someone know what the issue would be? Thanks in advance!
Re: Cannot turn crazyflie 2.0 off
It sounds like you have entered bootloader mode. You should be able to turn on/off the Crazyflie 2.0 by pressing the power button with a click, if you hold it down for 3 seconds or more while powering it on you will enter bootloader mode and the M2 and M3 LEDs will blink.
If you're still not able to turn off your Crazyflie could you post a short video showing what's happening?
Neon22
Post by Neon22 »
Mine got jammed up. I need to powercycle by disconnecting the battery (while unplugged from USB of course).
Then when I reconnected - I could use the power switch (hold down for 3 seconds) to get back into bootloader mode and update fresh.
