I haven't been able to get "reset to bootloader" option to work with `cfloader` as suggested in https://github.com/bitcraze/crazyflie-f ... xample#L24
It seems to be hanging up here https://github.com/bitcraze/crazyflie-l ... t__.py#L91
I've done a little bit of source diving so far, but wanted to check in here first: does anyone have this working and have suggestions for what may be broken?
Thanks,
-Chris
cfloader reset to bootloader not working
ccpost
Re: cfloader reset to bootloader not working
I will not be very useful but, for info, we are not using this functionality very often so it is possible that it have been broken at some point. Though I am pretty confident that the firmware part is still working: it is used by the go client (crazyserver) and is working, so if something is broken it is more likely to be in the python crazyflie lib.
ccpost
Thanks, knowing that it's likely the Python library is a good start, and I'll check out crazyserver regardless.
Not on the top of my TODOs, but I'll update this thread later if I get it working.
