xxchang
Post
by xxchang »
Hello!
My MAV has a less communication range. I tried three groups (100/2M, 0/256K, 80/1M).
What is your options?
Post
by arnaud »
What range are you observing?
2M is good for indoor as it will reduce collision with other 2.4GHz radio.
250K should yield much more range, but will have more problem cooping with a lot of other 2.4GHz radios (like wifi/bluetooth).
/Arnaud
xxchang
Post
by xxchang »
It's below 50 cm around my crazyradio. Awakward!!!!
Post
by arnaud »
Are you testing with direct line of sight or with obstacle? What radio parameter (channel and datarate) are you testing with?
xxchang
Post
by xxchang »
channel 100 and 250k
Post
by arnaud »
Can you try a lower channel, like 40? How about your test, are you in direct line of sight or are there any obstacles?
