Could you tell me which changes I should do to this code https://github.com/bitcraze/lps-node-firmware for the anchors to run in TDoA mode skipping the normal set up?
Also, with just one anchor will it still send the normal TDoA packet? (I know it won't work... just for convenience in the first stage of work)
Thank you!
