I have 4 separate crazyflie 2.0 quadcopters which I connect one at a time to the virtual machine provided on the startup website. I started having problems a day ago where the crazyflies would connect to the VM but then it would not show battery life, pitch/roll/yaw on the display, and I couldn't send it commands with my gamepad. It would register as connected and I could flash the firmware but that was it. I used the debugging steps on the forum post below, and now I can write commands to all the quadcopters but it still won't show battery life and the flight data display is stuck on the default screen that it is when the VM opens. any ideas for what I can do?
viewtopic.php?t=1776
Crazyflie 2.0 cfclient flight data and battery life displays not working
ben
Re: Crazyflie 2.0 cfclient flight data and battery life displays not working
Is everything updated to the latest version? There has been a bug recently where new functionality in the client was setting up too many log block, this has then been fixed by increasing the maximum number of log block in the Crazyflie firmware.
