hi, arnaud:
have we support the lps anchor send the fix-position to crazyflie, then crazyflie can recive the distance and anchor position to calculate itself position ?
how to configre the anchor position to anchor eeprom?
where anchor position save?
justinleeyang
Re: where anchor position save?
hi, arnaud:
client can config the anchor position ?
Currently, only in two way ranging mode, you can write the anchor position in the anchor using the client. If the anchor position is setup a stock crazyflie will be able to fly without extra configuration: it will receive the anchor position from the system.
