Crazyradio Dongle Will Not Attach to VM
khazamondo
Post by khazamondo »
I am trying to run the virtual machine for development, and when I attempt to attach the crazyradio to the virtual machine as instructed it says
"Failed to attach the USB device Bitcraze Crazyradio PA USB Dongle [0053] to the virtual machine BitcrazeVM.
USB device 'Bitcraze Crazyradio PA USB Dongle' with UUID {7981712f-3c17-4ef8-ae0f-9f913e2efc79} is busy with a previous request. Please try again later.
Result Code: E_INVALIDARG (0x80070057)
Component: HostUSBDeviceWrap
Interface: IHostUSBDevice {c19073dd-cc7b-431b-98b2-951fda8eab89}
Callee: IConsole {872da645-4a9b-1727-bee2-5585105b9eed}
I can get the windows client to scan and connect, so I have the right drivers, why wont the VM play nice?
I haven't found anything like this other than one post on the oracle forums with no responses. Please help! I dont want to have to develop on windows!
Re: Crazyradio Dongle Will Not Attach to VM
I have seen this message, usually when the usb driver is not installed. If you have installed the libusb driver you can try libusbk, or vice-versa. You could also try winusb though unfortunately the client is not yet compatible with winusb.
