Cannot compile CF2 firmware with latest build
sali0
Post by sali0 »
Hello Bitcraze,
I finally got around to updating the firmware for our drones, but when I use make, it gives me the error
*** No rule to make target 'sensors_task.o', needed by 'cf2.elf'. Stop
I tried searching for which file it was referring to but I cannot find it anywhere. What can I do to complete the compilation? Thank you.
Re: Cannot compile CF2 firmware with latest build
I guess you are compiling for autonomous flight and you have
SENSORS=task
in your config.mk. If so you should just remove this line from config.mk. The sensors_task file has now been merged into the stock sensor file.
