Hi there,
it's me again..
I am currently using the CF2 with the LPS. Every works just fine, if I move the CF in the room the CF-position is moving accordingly.
But I just can't get the CF to take off, when I use ('dwm_loc_ekf_hover.launch'), I think mainly because I am using a PS3-Controller instead of an XBOX360, i do not own one.
Is there a possibility to use the launch-scripts with an PS3-Controller for take-off, etc.?
Best regards,
Christian
Using PS3-Controller with LPS
Re: Using PS3-Controller with LPS
Hi Christian,
Nice that you get some position estimate!
To use another king of gamepad you need to modify this file from the crazyflie driver: https://github.com/whoenig/crazyflie_ro ... py#L38-L54
You can find your gamepad mapping by running (one command per console ...):
This will allow you to see where the different button are mapped and to modify the code accordingly.
Best,
Arnaud
roscore
rosrun joy joy_node
rostopic echo /joy
Best,
Arnaud
