ImportError: No module named 'cfloader'
Posted: Wed Sep 28, 2016 9:42 am
by gurkbert
I'm experiencing some errors when i try to update the firmware of the crazyflie 2.0. I have no problem to compile the code using 'make' but when I try to use cload i get the following error:
~/Workspace/crazyflie-firmware$ make cload
../crazyflie-clients-python/bin/cfloader flash cf2.bin stm32-fw
File "../crazyflie-clients-python/bin/cfloader", line 2, in <module>
from cfloader import main
Makefile:354: recipe for target 'cload' failed
make: *** [cload] Error 1
I'm using Ubuntu 16.04. Does anybody have a suggestion on how to solve this problem?
Re: ImportError: No module named 'cfloader'
Posted: Wed Sep 28, 2016 10:06 am
by arnaud
This looks like what would happen if you did not install the client with pip. Did you do it as described in the readme:
https://github.com/bitcraze/crazyflie-c ... pplication?
Posted: Wed Sep 28, 2016 11:45 am
by gurkbert
I installed cfclient using the following command and i seemed to execute properly:
~/Workspace/crazyflie-lib-python$ pip3 install -e .
The installation of the dependencies also seemed to work.
Posted: Thu Sep 29, 2016 8:36 am
by tobias
And did you install the
crazyflie-clients-python as well?
Posted: Thu Sep 29, 2016 11:31 am
by gurkbert
I'm not sure that i understand, isn't that what
is for?
Posted: Thu Sep 29, 2016 1:29 pm
by gurkbert
I managed to circumvent the problem by adding the paths manually:
export PYTHONPATH=/home/myname/Workspace/crazyflie-clients-python/src/
Will this turn out to be problematic in any unexpected way?
Posted: Tue Oct 04, 2016 9:44 am
by arnaud
If it works then it is good, though it is very strange that pip did not work. This is basically what pip should have done for you. I will run some test in a vm with a clean ubuntu to try to reproduce the problem.
Posted: Thu Oct 06, 2016 10:54 am
by arnaud
I cannot reproduce the problem. On a clean Ubuntu 16.04 I did:
sudo apt-get install python3-pip
git clone https://github.com/bitcraze/crazyflie-clients-python
cd crazyflie-clients-python
pip install --user -e .
sudo apt-get install python3-pyqt4 python3-pyqtgraph
cfclient # works
cfloader # works
