ImportError: No module named 'cfloader'
gurkbert
Post by gurkbert »
I'm experiencing some errors when i try to update the firmware of the crazyflie 2.0. I have no problem to compile the code using 'make' but when I try to use cload i get the following error:
~/Workspace/crazyflie-firmware$ make cload
../crazyflie-clients-python/bin/cfloader  flash cf2.bin stm32-fw
  File "../crazyflie-clients-python/bin/cfloader", line 2, in <module>
    from cfloader import main
Makefile:354: recipe for target 'cload' failed
make: *** [cload] Error 1
I'm using Ubuntu 16.04. Does anybody have a suggestion on how to solve this problem?
Re: ImportError: No module named 'cfloader'
This looks like what would happen if you did not install the client with pip. Did you do it as described in the readme: https://github.com/bitcraze/crazyflie-c ... pplication?
gurkbert
Post by gurkbert »
I installed cfclient using the following command and i seemed to execute properly:
~/Workspace/crazyflie-lib-python$ pip3 install -e .
The installation of the dependencies also seemed to work.
And did you install the crazyflie-clients-python as well?
gurkbert
Post by gurkbert »
I'm not sure that i understand, isn't that what
pip3 install -e .
is for?
gurkbert
Post by gurkbert »
I managed to circumvent the problem by adding the paths manually:
export PYTHONPATH=/home/myname/Workspace/crazyflie-clients-python/src/
Will this turn out to be problematic in any unexpected way?
If it works then it is good, though it is very strange that pip did not work. This is basically what pip should have done for you. I will run some test in a vm with a clean ubuntu to try to reproduce the problem.
I cannot reproduce the problem. On a clean Ubuntu 16.04 I did:
sudo apt-get install python3-pip
git clone https://github.com/bitcraze/crazyflie-clients-python
cd crazyflie-clients-python
pip install --user -e .
sudo apt-get install python3-pyqt4 python3-pyqtgraph
cfclient # works
cfloader # works
