I am trying to use big quad deck with crazyflie. I am able to attach the deck correctly and I can power the crazyflie with the quadcopters battery. Although in the client I get the following message in console and my ESCs are not getting any signal.
DECK_DRIVERS: Found 6 drivers
DECK_INFO: Warning! No driver found for deck.
DECK_CORE: 1 deck enumerated
EEPROM: I2C connection [OK].
AK8963: Self test [OK].CFGBLK: v1, verification [OK]
LPS25H: Self test [OK].
SYS: Free heap: 4656 bytes
What is this warning for? Also I dont get a message for switching to brushless mode.
Big Quad Deck no signal to ESC
Re: Big Quad Deck no signal to ESC
Welcome to he forum!
As the BigQuad-deck is in early access stage and a bigger quad requires certain safety measurements the BigQuad FW needs to be manually built as described in the wiki page.
