Step by step guide to fix USB 3 problem
Indieflow
Is there any chance someone could write a simple guide on how to flash the firmware on the Crazy Radio as I'm really stumped?
I have the software all setup working on an old computer though want to flash the firmware so that I can use the radio from a new laptop.
I've looked at this wiki page http://wiki.bitcraze.se/projects:crazyradio:programming though when I attempt the first line of code in the Command Prompt window I receive "The system cannot find the path specified".
When I go to this page https://bitbucket.org/bitcraze/crazyrad ... /downloads I only see a bin file and the drivers, where is the firmware?
Any help would be greatly appreciated!
atomicdog
Re: Step by step guide to fix USB 3 problem
Are you using the Ubuntu VM bitcraze supplied? The instruction assumes you're starting in the HOME directory.I have the software all setup working on an old computer though want to flash the firmware so that I can use the radio from a new laptop.
The bin file is the firmware.When I go to this page https://bitbucket.org/bitcraze/crazyrad ... /downloads I only see a bin file and the drivers, where is the firmware?
Indieflow
Yes I'm using the Ubuntu VM bitcraze supplied, where is the home directory sorry?
Also where should I place the bin?
atomicdog
Actually, I was wrong the instructions assume your already in the projects directory.Indieflow wrote:Yes I'm using the Ubuntu VM bitcraze supplied, where is the home directory sorry?
When you first open up the terminal you'll start out in the HOME directory which is /home/bitcraze.
Then you can use the command cd to change directory to /projects/crazyradio-firmware.
cd projects/crazyradio-firmwareThe default place for files to be downloaded is download ( /home/bitcraze/Downloads ).
The bin file can be anywhere that's easy for you to remember though. You can move the bin file to /home/bitcraze/projects/crazyradio-firmware in order to match the instructions more closely. Or, use the full path of were it was downloaded.
python usbtools/nrfbootload.py flash /home/bitcraze/Downloads/cradio-0.51.bin6-DOF CF | wireless xbox 360 controller
- Contact:
The instructions for the Crazyradio firmware upgrade has been updated and now includes a step-by-step guide to upgrading using the Bitcraze VM. The instructions are located here.
/Marcus
/Marcus
swangy
here's the error i get when i try to launch bootloader.py?!
help anyone?
help anyone?
retinapro:usbtools$ python2.7 ./launchBootloader.py
File "./launchBootloader.py", line 27, in <module>
import usb
ImportError: No module named usb
- Contact:
Have you installed pyusb and libusb? Have a look here for a list of dependencies. The list is for the client, but it includes the dependencies for the radio as well.
swangy
yes, followed the list down the installation dependencies..
is the issue because i'm trying to do it on the mac pro with the USB3.0 port? do i need to do it in a usb2.0 computer?
- Contact:
No, this isn't the USB3 issue. It's that python cannot find the usb packet (pyusb).
swangy
it looks like a native OSX python vs my 2.7 version install conflict... grr. wil do some digging and post back results on solution..
