[SOLVED]helper.inputDeviceReader not linked
Mitteau
Post by Mitteau »
Hello everybody,
I am trying to install flip-flop on althold command. Everything works fine except:
I cannot send the command to InputReaderInterface instantiated class. The command seems to be
self.helper.inputDeviceReader.enable_alt_hold(enabled) - line 179 in FlightTab.py
but the command does not reach enable_alt_hold in InputReaderInterface.
Thanks to say her I am wrong.
Regards
Jean-Claude
Mitteau
Re: [SOLVED]helper.inputDeviceReader not linked
Post by Mitteau »
Hi
To implement flip-flop command for althold, you need a "bascule" routine. This method have to be installed in inputDevice class, in .../input/inputreaders/__init__.py and not in FlightTab.py.
Regards
Jean-Claude
